Thank you everyone for your help so far. I'm still diligently pushing through this issue spending an hour or two a day playing with this thing. Before I drag this thing 45 min to the lake for a test under load, already knowing the problem still exists, I wanted to take a stab at SROW's suggestion and test the trigger assembly. I don't want to get my hopes up here, as I've done that several times already. I tested resistance on the trigger with my meter. Using the service manual, I attempted to read the resistance between several sets of wires on the trigger wires while unplugged. I get no response from the ohm meter. I tested the meter against itself and it's working properly. Am I missing something here? I tested the trigger with it plugged from the boat matching the colors as indicated in the book. None of the connections changed the meter from 1, or the initial display when no circuit is completed. I tried all the settings on the meter in the ohm settings, as I'm not overly familiar with what setting it needs tested on (20k, 200k, 20m etc). Same result each time, or no result I should say. Can anyone give any advise on this? Is it safe to say I need to order the new trigger? Thanks in advance for any help.
