I've used the neoprene seal listed for the 1998 GTX Limited with no issues and no trimming needed. The Seal part number is listed on the parts list it is item number 7 but mis-marked as Pump Housing. There is a difference in later pumps but they use a different type of neoprene seal. The "293200051" seal does not hold the jet pump further away from the PTO... it fits on the Outside diameter. YMMV. Just sharing what I've enountered personnal. I have another 1998 GTX Limited outside... it's getting the neoprene seal when I installe the pump. Good Luck!
Click on #7 the 051 part number. You're correct if you click on the 936. It is strange but I'm not surprised with the parts. I have had many adventures trying to find parts using these drawings. Good LuckSorry for the dumb questions, I’m confused i dont see the 293200051 on the 1998 parts list #7 on the parts list is 271000936 which is the housing. I have the seal on hand so i might install it if it fits fine and doesn’t cause any issues
I use a neoprene seal on my 98 gsx limited, no issues.
