Justintime_3
This is a problem I was having and I think I have it figured out.
Here is what I did first. First check the check valve in the fuel line that comes from the fuel tank. When I pulled mine out I could blow through it one way and not the other. Thats how they are supposed to work but the one direction I could blow was very hard to blow through. I took the two halves apart and punched the ball spring and collet out of one half and cleaned and put back together but put them together so the ball could move around a little more.(Hope that makes sense)
Second thing I did was check the in tank filter on the bottom of the pick up. Mine was clean. I also changed the fuel filter that mounts directlty to the electric pick up fuel pump. Mine was also clear. I then removed the Vapor fuel tank and it has a filter on the bottom of the pump and mine was clean but there was a whole lot of stuff at the bottom of the canister. I drained the crud out and put it all back together and then rebuilt the pulse fuel pump just for shitsandgigs. I also drained the old fuel out as I wasnt sure how long it had been in there. Tooke her out last niight and she purred along perfectly.
And like I said I also follwed the manuals troubleshooting process and it really is pretty informative. So good luck and if you have any questions feel free to ask. And if you have any other questions you can post them up in my thread. You can also PM me for help. I am more than willing to help out the best that I can. Hope this helps anyone in this situation.
