So I picked up my first ever pwc..... YEAH me!!!! Now here is the kicker, the motor came in a couple boxes LOL
After getting everything out and in the open it appears that someone didnt winterize correctly as one of the jugs was popped. The sleeve was fine but the outer waterjacket was cracked outward. I cant say for certain but it appears thats what happened. It came with 2 extra jugs which appear to have been recently machined to 82.45mm and honed. Neither appear to have been used as the cross hatch pattern is untouched.
The bottem end is still intack and doesnt appear to have been apart. Spins freely blah blah but I have no clue to its condition.
Curious as to what you all think I should do. I would love to just throw a top end kit on it and roll but im worried about the bottem end. Can you all give specs and methods to check without tearing it apart. Or would you all suggest tearing it down and checking for wear. What kit or piston type would you use on the top end. Seems like I have heard that once you go back 82.25mm you should use a specific piston kit.
I got this ski cheap so I really dont want to put a lot into it, then again I dont want to throw a rod out the side either.
Any specifics you can tell me about the spx or 787 engines. Seems like everything I have read thus far is good.
Another off topic question is does anyone have a good way to flip a ski in order to do bottem work? There are some gashes I would like to work on but am unsure how to flip it safely?
thanks!!!!
thanks!!!!
