jjsinaz
So I picked up this 96 GTX on CL. I've been wanting a 97 for a long time and since they're basically the same ski i figured what the heck. I did not lake test it before I bought it. Checked compression , which was good and it started and ran so I figured I at least had something to work with.
Took it to the lake late Thursday afternoon and went for a ride. Ran like crap. The guy said he had the carbs rebuilt earlier this year, but I wasn't sure if it was starving for fuel so I opened the HS screws about 1/4 turn each. This only made it worse. So I put it back on the trlr and headed home.
I have been reading alot about these kind of problems and from what I've read the symptoms seem to lean toward a bad rectifier. Coughing, backfiring, tach jumping all over the place. I took the rear E box apart That night and it looked pretty good inside, so I cleaned all the connections in there and di-electric greased them and put it back together.
Pulled the carbs off and although I've only disassembled the Mag carb, it looks clean inside and I'd have to say the guy didn't lie abut the carbs being rebuilt. I will go through them both and make sure the needle/seats aren't leaking and that the pop off is correct, which BTW, what would the recommended pop off be for this ski?
Today I tor into the front e-box, and it was not pretty. A lot of corrosion on the rectifier and looks like it has been getting moisture in it. The tops are blown out of a couple of thise things that screw on to hold/seal the wire ports, so I suspect that is where the moisture has been getting in. I think I can fix those with a little JB weld.
I'm going to clean everything up in there and replace the rectifier, since it is so nasty looking (see pic) and I also read that the rectifiers were problematic on this year/model ski. It looks liek someone might have put this one in uses, as it looks like they tried to clean the plate that it sits on in the ebox.
The other thing concerning me is that the plastic on the MPEM is cracked on the one end. See Pic. Do you think I should go ahead and use it or replace it? I don't think water could get into it and it seems like it was working okay. Don't know if this could contribute to my running issue or not
