Major Woody
Gelcoat repair on bottom of ski is now done other than needing a bit of color sanding to blend into existing.
Materials used: Gelcoat from Fibreglast.com, tinted to RAL 1018, Duratec High Gloss Clear, and MEK-P catalyst. Gun used: cheap 2.4 tip HVLP primer gun ordered online, 40 PSI.
Mix gelcoat and Duratec 50-50 and then add 2% catalyst. You have about 15 minutes to spray. Surface was sanded to 150 except in the area to be blended (320 there). The color match is quite close. The photos make it look worse than it actually is. If this was in a highly visible part of the ski, I would cover all surfaces though.
This stuff is EASY to spray and requires no sanding or buffing afterward at all. Very high gloss and excellent build.
Honestly I don't understand why anyone with $30 for a cheap HVLP gun, access to a compressor and an indoor spot to spray would roll on gelcoat and then spend an eternity sanding and buffing it when you could just spray it and be done.
