A little bit more about the work on the seat. The seat on this was not terrible when I got it, but had damage. At the center front, the vinyl had either torn or shrunken back to where the foam was exposed. The sun had hardened the foam and the area around it was raised and crusty. The plastic corner covers were MIA. There were a couple small tears in the cover. On my GSX, the seat cover and the foam are fused together so your only real option is to glue a new cover to the old one. On an XP, the cover is not glued to the foam so you can remove it entirely and reshape the seat if you want to.
Once I had taken the old cover off, it was obvious the cover had a significant "dip" where the strap was, plus the damage at the front where the sun attacked it, plus a tear in the foam on the right side. Additionally, the little corner protectors don't match the new seat cover so I wanted to clean up and reshape that area and get rid of the protectors. I used a DA sander and an air file aka "jitterbug" sander to flatten the foam. This completely eliminated the dip where the strap was, and re-shaped the crusty area at the front of the seat. Believe it or not you can sand this foam if you use a coarse enough grit and the right sander. In the photo, you can see the shadow of where the strap was, but the dip is gone.
Next, I used ProPoxy 20 epoxy putty to reshape the plastic seat frame where the strap is and where the corner covers are. Sanded that smooth to match the existing contours of the seat.
Finally I used Dynaflex 230 caulk and a bondo spreader to re-contour the foam and repair the rip in it. Multiple thin layers are key. This is the last step, as you cannot sand caulk. The caulk is firmer than the foam itself, so I would be reluctant to use it in the main part of the seat. For major damage, it would be better to find a better seat and start with that.
Above is a photo where I had started to apply caulk and then realized I had more sanding to do. I had gotten ahead of myself and had to peel some away. I don't have any photos of the final layer of caulk but it ended up being super smooth. I used it to smooth out the sun-damaged foam at the front edge of the seat.
This picture shows the side where the foam was ripped. Fill rip with caulk, use masking tape to hold it shut while the caulk cures, then a thin skim to smooth out the repair...invisible.
Anyway I am pleased with the way the foam and seat frame turned out. The seat cover lays smoothly over it, doesn't dip in where the front corners are or where the strap was, and there is a smooth transition where the foam meets the rounded plastic frame.
The end product:
and yes, I used stainless staples.
Not too shabby for a $66 Black Friday cover!
