I rebuilt the carbs on my otherwise perfectly running 197.5 hr GTX this spring
and to my surprise it RPM'd to 7000 rpm for the hole shot on take-off then settled to 5000 @30 mph. PTO plug fouled some what.
I pulled the carbs to check the issue w/PTO carb and I found that the entire bottom of the motor was filled w/gas.I mean FILLED to OVERFLOWING!!
I had to pull the balance shaft plug to get the gas out,but there is some left @lowest part of motor.I still smell like gas...mmmmm love it
Do I have to pull the motor an tip it on end?I changed the fuel lines on the carbs.I don't thinlk that I mixed the lines up??
Could I have really wrecked the motor?
