MP3 an XP?
mthomp7
is it possible to put marine speakers and an MP3 hook up on my 96 XP and how much am i looking at to have it done?
anything is possible, however I have came to the same thump in the road.....pwc's require the best marine speakers anything less is a waste of money as they come apart fast do to the elements at hand in marine use where as a boat the speakers are not as exposed.
Most get an amp and 4 speaker system, your mp3 plugs right into the amp via a cable. The 4 speakers go where ever you want to cut a hole for them, I do not recommend the mirror speaker mounts as you really need those mirrors if you have them.
Price wise I have seen them from $500 up to about $900 or so. Can you get away with a couple hundred?......yes but you will be replacing everything within couple of months.....mounting.....typical mounting is where ever you will hear the sound best....amp gets mounted inside, I would mount it out of dict water contact.
I tried it on my last ski and it kills the battery in about 45min if not running.
Not for nothing, but that comes with the nature of the beast......the battery cannot charge if the engine is turned off, I always suggest a 2nd battery with the addition of a stereo so that the stereo/electronics battery is isolated from the starting system. Yes if the engine is turned off and your stereo is cranked then you will kill the battery within a certain amount of time, thats why the engine must be running to charge it, however if you isolate 2 seperate batteries and run nice not cheap batteries you can have the engine off and get quite a bit of time before you have a problem, I would run 2 batteries and a dual batt switch
Yeah I thought about that but I like fast more than music so I didn't want to add the extra weight.It can be done and I have seen some pretty nice set ups but it has to be done right.The only way to make it useable would be a second deep cycle batt.
