Hi there
I have a Seadoo Challenger 1800, 210 M2 that was rebuilt last season after blowing a piston pin. The boat ran great after rebuild, and most of this summer, then randomly wouldnt re-start after sitting in the water for awhile, then it would only start on the trailer, took it to the marina that rebuilt it and it started 10 times in a row so they said there was nothing wrong (still charged me $150...) took it home it started in the driveway, launched it and no go again. Took it home and no go once again..I replaced the spark plugs, and the gas is new.
** Now there is no spark!?! I even pulled a few plugs and held my thumb across the terminals on the flat plug while it was turned over and nothing! no spark!
-Fuel primer ok
-Fuel pump pumping
-Gas fresh
-Fuel filter ok
-Fuses ok
-Ignition single beep (supposed to be all clear signal)
I cant imagine all 6 coils going at once, so the ignition compuer/MPEM?? I hope not, thats not a cheap part..
ANY HELP IS GREATLY APPRECIATED!! Is there a sensor that I should check that would give the computer a "no-start" signal???? I cant find a water pressure sensor on the motor...
Thanks! Brandon
-Fuel primer ok
-Fuel pump pumping
-Gas fresh
-Fuel filter ok
-Fuses ok
Thanks! Brandon
