Robert wilson
I have a 2007 seadoo rxp 215 with 140 hours on it has for the last year always said low voltage after start up then went away second later. A few days ago it actually had the low voltage code come on and alarm. Brought home checked batter it’s at 12.4 and 14.2so I checked stator and checked ohms and I’m reading 0.8 and 0.9 which is in spec hook it to computer and it says only 11.4 volts. I tried different machines voltage rectifier and didn’t change any really other then when running was reading 14.5 on the battery I had voltage on fuse but while not running the top of the fuse holder has 4.5 lots still and this was measured with volt meter with out fuse in and while not running also I checked the wire to stator and they are fine the ohmed out fine.
