Start from the middle and work diagonally 1/4 turn at a time 2 or 3 times and then once they are all loose you can take them out.
I find that after cracking a few loose they become tight again as the next set are loosened. So just take it a bit at a time and you'll find after a bit they all feel free.
Its pretty straight forward.
BUT before you start I'd recommend grabbing the crank and setting the piston's at equal heights. This will block the transfer ports and anything you drop in the cylinder will not go anywhere.
FYI when your re-installing a head: Its grease on the threads of the bolt and blue locktite under the head. Sometimes the manual can be confusing about that part but this will make taking them out easyer next time. Also there is a two stage torquing procedure. First time torque to 9 ft lbs and then up to 17 ft lbs for the final. Mainly your just squishing down the gaskets in small amounts before really pushing the head down.
