Thought I'd paste in the instructions that Tony sent me, and add my story to the thread.
Directions:
1) Use the long tool, and put it thought both bearings, and seal, from the rear of the pump. (the side from the cone)
Then... just push it all out the front.
2) Use the short tool, with the side with the step to install both bearings. (one from the rear, and one from the front) Put the bearing on the tool with the stamped side facing out, when installed in the pump. (so put the numbers toward the tool)
The tool is deigned to put the bearings in at the proper depth.
3) Use the side of the short tool with the recess in it, to install the seal. (it's the side that has the extra ring) The recess will keep the rubber lip safe. PUT SOME GREASE ON THE RUBBER SEAL !!! that will keep you from accidentally nicking/damaging the seal. You can put the seal into the pump dry... but a little sealant will assure that it's sealed. I use a little black RTV just lightly wiped into the pump housing.
It's done. Easy.
When you put the pump shaft back in... it's possible to pinch the thrust washer in the back. SO... if you tighten the impeller... and it doesn't turn free... loosen it a little... and make sure everything is straight."
My story:
I just rebuilt my first jet pump and the tools from DrHonda were a Huge help.
I was able to drive the first bearing loose with a socket, extension, and rubber mallet... but couldn't keep the first set of bearings aligned inside the pump housing so I could drive out the 2nd bearing and seal. I don't have a press, but I ordered the tools thinking maybe I could use them with my mallet. Turns out the mallet bounces too much, and my dead blow hammer is on my big boat at the lake 2 hours away. I thought that my E150 conversion van would be heavy enough, so I put the pump on my floor jack under the van, and jacked until the bearing removal tool was touching the van's frame... I figured that as I jacked this would be approximate a press.
Didn't work.
It actually lifted the front of the van off of the ground, but the bearings didn't budge. After scouring Craigslist unsuccessfully and almost giving up and heading to HF for a press, I found a friend with a press and he was able to press out the bearings pretty quickly. I admit to being worried when he had to pump the press a bit to get the bearings and seal loose. They made a pop sound when they broke loose and I was nervous that something broke... but in retrospect, the metal part that the bearings and seal were in was supported on the press. So, the only thing that could move was the bearings and seal. I had frozen the new bearings, so they went in easily with the installation tool, and to just the right depths. The seal went in nicely too.
My friend commented that he has been using the press his whole life (3rd generation family business, a towing and recovery shop), but never had the pleasure of using such a nice tool that was custom built for the job.:drool5:
I really HATE to spend money on job specific tools that I'll likely only use once, but this tool set from DrHonda was well worth it, compared to the obscenely priced tools from SeaDoo.
And Tony shipped it the evening that I purchased it and got to me quickly.
Oh, and even with Tony mentioning not to pinch the thrust washer when i put it back together, I somehow managed to on the first try.
