The title might be a little misleading. Obviously this motor is toast at the moment. The real question is can I rebuild it?
I have attached some pictures of the damage that was caused in the block as well as a couple of pictures for the cylinders and pistons.
My main question is if I put a new crank in will the rest of the motor be fine.
*Keep in mind that the only thing I actually cleaned before taking these pictures is the bottom half of the block. The top half of the block, cylinder, and piston were not cleaned up so you may see some flecks of metal in some of them still (especially the upper half of the block).*
Block - Has the pitting gotten to a point where I need a new block? It does not seem to be all that bad to me, but I wanted some opinions from those of you much more experienced guys out there. Another question with the block is; are these things able to be machined/honed?
Cylinder - I am seeing little to no damage, in fact, I can still see the cross-hatching on most of the cylinder. What do you guys think?
Piston - Though I can visibly see these verticle lines on the side of the piston when I feel them it feels perfectly smooth.
Just trying to weigh my options here. Should I just go ahead and buy a whole new motor from SBT, or can I get away with just buying a crank and slapping it in this thing?
I can always take some more pictures, just snapped these off real quick before I had to walk away in disappointment (lol).
I appreciate any input you guys have for me and know that I am in a bad situation already so no sugar coating necessary.
