Dbrown6240
Why so much hate for the DI? I personally think it is the best SeaDoo motor ever built and the design was years ahead of its time. A very technical motor that most don't understand. Not difficult to diagnose or fix if you understand it and have a little experience with it.
Carb 951s are good too, still rebuild them on a regular basis and many times from people using the wrong oil which is what your new ski has in it. XD50 is a TCW3 oil and not recommended for your ski and it will tell you that right where the oil cap is located on the ski. Seems most people don't know how to read anymore. Some people will say that TCW3 works fine but SeaDoo did testing and published results back in the day that showed piston wear with their full synthetic xps oil and several others including tcw3 oils. Are they biased? Of course, but I believe their results based only from experience that skis that I service and the people only using XPS full synthetic that the engines last longer. Do they still blow up? Yes, all 951s have a limited life, that is the design, but they absolutely last longer in my opinion with the proper oil.
You should check compression. Then change oil to what is recommended by the manufacturer.
So can I start using the oil recommended or do I need to run the old out first?
