5 519bryguy New Member May 15, 2009 #1 I have a seadoo RX 951 and cant tighten the bolt that holds the exhaust on to the manifold! Is there a special tool for this?! PLEASE HELP
5 519bryguy New Member May 16, 2009 #3 No its not stripped I cant get a wrench in by the pipe to tighten the nut on the STUD
Chester Premium Member Premium Member May 16, 2009 #4 Do you have the carbs off? It's a lot easier to do before you install the carbs. Chester
5 519bryguy New Member May 16, 2009 #5 No I have the carbs on everythings ready I think just that one bolt needs to be tight
Chester Premium Member Premium Member May 16, 2009 #6 Unless you have the curved wrench from BRP or Snap-On, it's way easier to pull the carbs off. Chester
jwick86 New Member May 17, 2009 #7 When I'm working on my XP I put the exhaust on and tighten the nut then put my carbs on under it. Just as easy for me and no special tools needed.
M mustangturbo50 New Member Jun 18, 2009 #8 tool does anyone have the snap on part number or what it is call. my snap on dealer cant find it. sea do can get it for me but i like snap on more.
Chester Premium Member Premium Member Jun 19, 2009 #9 The Snap-on tool is a CXM1519 but you will have to grind it down to make it as thin as the BRP tool so that it will fit over the nut. Chester
M mustangturbo50 New Member Jun 19, 2009 #10 snap on yeah so the tool from snap on it 4 times the price of course and is not the right one and i still have to grind it. so ill stick with the 26.00 dollar one from seadoo themselves
