Willie_Boi
Over the weekend I bought a 1996 Seadoo XP with the 787. I picked it up and it will idle, but it will not take throttle. As soon as you start to give it about 1/4 throttle it starts bogging and backfiring through the carburetors. The previous owner said he just had them rebuilt and had the wear ring replaced. I immediately started testing and going through forums looking for answers but i am being stumped on what to do next. Compression is 150 both cylinders, plugs regapped, rectifier is at 13 volts from what I could tell and it did not act differently after unplugging the red wire. Whoever did the work on it replaced all the hoses, spark plugs and rebuilt carbs added an inline fuel filter right before the entry on the bottom connection for the carbs. When I first turn it on the inline filter is full of fuel but quickly gets sucked in after started and then while running there’s only about an 1/8 worth of fuel flowing through it. Once you turn it back off it fills back up. Any tips or advice would be greatly appreciated. Thanks for your time -Willie
