Is that normal for the Islandia? I guess it is a much heavier boat then the Challenger. Mine with a worn out wear-ring and compression averaging 100, still gets 47mph at 5600rpm.
Nope... that's a little slow.   Officially... it should be 42~43 mph as I recall. My boat will do 35 without trying very hard. (75% throttle, top up, and 6~7 people)
SeptemberC: Did you take a midnight ride? (LOL)
Anyway... the RPM's are low.  If you can find another 400~500 RPM, you will find another 8 mph. With a jet pump... you really add a lot of pressure with a small change in peak RPM's. But, at this point, I wouldn't get too excited. Lets get a tank of fuel though that engine, both to knock out the cobwebs, and to make sure we have fresh fuel.   After that... the next steps will be to:
1) Make sure the throttle is opening all the way.
2) Check peak ignition timing.
3) Double check our static compression numbers.
4) Make a run with your bilge fan on.
I know that last one seems simple, but it will assure clean, fresh air for the engine to breath.
Do we know the running hours on your engine?  Was it ever rebuilt?
