Guest_User
I learned something in this thread!:cheers:I'm glad this got back on topic.... I would sure hate to see another "oil" thread! :facepalm: :lol:
Have the battery load tested. If it us good then I would agree that your starter is bad.
If so, and if it is an OEM starter, rebuild it. Used OEM is better than new aftermarket.
Well I guess I'm still learning the hard way, pretty sure its a oem starter... An SBT starter will be here Friday, hope those are ok. I will rebuild the oem starter this winter and prolly swap it out later, I gotta get this thing fogged this weekend, it's starting to cool off here.
The old oils have been made for a very long time... and I'm sure BRP doesn't care about the old engines. So, where my issues are... I'm sure there was ZERO testing to find if the oils were compatible, or the effects on the RAVE's.
I've been loyal to XPS, and I get a good price local... but since I'm being forced to switch oils... I guess I'll buy the stuff from wal-mart now. (Quicksilver PWC)
Or........
I'll sell both of my 2-strokes next spring, and buy a spark.
OK... not to get too far off subject... but I wonder if the Synth base in the Red-Line oil caused the center seals to leak??? I remember, back in the day... the real synth oils would show you all your weak seals, via oil leaks. I'm not saying it caused the leak... but if it's thinner (on the molecular level) it will get past a warn seal.
SBT is really no better from all that I have read, that said,,, it will certainly do what you need in regards to getting it winterized.
And did you load test the battery?
Actally I load tested the year old battery at Oreilys the day before you recommended it and tested good. So I have been burnt a time or 2with the load testers at the autoparts stores. I bought a new 575 amp battery anyway(the guy thought I was nuts) , making sure to eliminate the battery. I top that battery off to 100% according to my Diehard charger.. I'll slap that starter in this Friday or Saturday and report back.SBT is really no better from all that I have read, that said,,, it will certainly do what you need in regards to getting it winterized.
Can`t be to sure about that joe, I`m running 2 SBT starters this season, and they do the job just fine...
I think they might have changed vendors since all those complaints, and 99% of that is user error...:facepalm:
What type of user error did you see? I don't want any user error here...
Tony,
You are one if not the most respected members of this forum, and you certainly have my respect. BUT I think you are over-reacting on SeaDoo changing the vendor for XPSII. I don't want to hi-jack this thread so I will start another dreaded oil thread. Now where did I see that cat?
Lou
@DrHonda - I wonder if there is any truth to this? I just purchased a 1999 Seadoo Challenger (From the original owner), with both motors that appear to have bad crank seals. He claims he never had any issue with the crank seals until the new XPS-II oil was added to the boat which was over the last year or so. He used XPS-II from the day he bought the boat back in 1999. He noticed this spring that the both motors were full of oil, and the last gallon or two he added was the new red stuff (Verified by what is coming out of the spark plug holes and what little was left in the oil tank). Seems a little strange and coincidental to have both crank seals to go bad at the exact same time shortly after switching to the "new" XPS-II oil.
I don't want to get this topic to far off, because I am (as several others in this thread) are in the same "boat" with bad crank seals. I still have to get a little more oil out of the motors before I can get them running. I've done a lot of reading, but haven't found a clear answer so maybe I can get that answered here. Is there a clear way to tell whether or not the issue is the Crank seal, or the Rotary Shaft Seal?
Maybe a self-explanatory question, but should I pinch off the oil line while I am trying to crank out the oil to prevent more oil from going in, or do I want to keep that flowing to make sure everything keeps getting oil (even though there is plenty in there now!)? For those who have purchase a valve for the oil line(s), what did you end up using?
Thanks!
I installed a shut off valve on my oil lines and pull the spark plug cables as a reminder to turn the oil on when I plug them back in. However a local Seadoo mechanic I met last weekend told me that frequently it is the Oil line check valves that fail and allow oil to fill to the cylinders. Apparently there is a spring loaded ball that will fail over time (spring loses tension) and allows oil to bypass the valve. Anyone else heard of this? I would sure like to resolve my issue if it is that simple..... I assume there is one valve per cylinder if that is the case?
