Eclipse1701d
Hey guys.  I am trying to remove the J-Pipe to check for blockage on my 2007 Utopia 205.  I was able to easily remove the starboard side, but I cannot get the port side off.  Any advice?  I loosened the screw all the way, but it won't go down far enough to release the t-bar.
I am doing this because if I run over 6000 RPM I get a check engine light on the port side with one long and very loud beep. I am theorizing that one of the three holes are blocked and this happens over 6000RPM because it can't keep the exhaust cool enough... Without removing the j-pipe, I used a compressor to blow out all the hoses, but it is still happening.
Help would be GREATLY appreciated!
I also noticed that my starboard water box is missing the strap to hold it in place, which I ordered. I am glad I found it before I stressed out the starboard j-pipe. I see that it is one expensive part!
