How to Build your own Pop Off Tester with Parts from Lowes
leepoffaith
There are several threads on how to build your own pop off tester, but some are missing pictures and others give you items from Home Depot, so I thought I would start a thread with how I made my pop of tester with items from Lowes. I am brand new to Jet Skis, so if I can do this YOU can do this too. :) It cost me a little over $25 dollars. I do want to give credit to advacomp because I used his thread on building one from Home Depot as the basis for mine.
Parts Needed:
1. 1/4" Air Hose Plug (Item #15306) - Located in air tools section. No packaging, just a little tag on it.
2. 1/4" Pressure Gauge (Item #221022) - Located in air tools section. In Kobalt packaging
3. 1/4" Mini Ball Valve Knob (Item #221029) - Located in air tools section. In Kobalt packaging
4. 1/4" Brass Pipe T Fitting (Item #34833) - Located in plumbing section. Watts packaging with pink stripe on top
5. 1/4" Brass Hose Barb with 5/16 Barb (Item #22340) - Located in plumbing section. Watts packaging with purple stripe
6. Teflon Tape (Already had so not in picture or receipt)
Copy of Receipt
Picture of Pop Off Tester
A couple of tips:
- The ball valve is VERY touchy so go very slowly when increasing pressure
- I would not advise using this for anything that requires very low pressure. The pressure builds so quickly you could easily break a seal or diaphragm
- I used left over 5/16 fuel line hose for testing. For the MAG carb, the pop off tester is attached to the only 5/16 hose attachment on the whole carb. For the PTO carb, you attach the hose to the 1/4" fitting on the side of the carb. You can still use the 5/16 hose, just put a hose clamp on it.
That's about it. If you have any questions, feel free to ask!
