I'm now having a problem with the oil valve cable that connects to the carb. At first it did not retract at all and cable seemed too long. Then I discovered how to get the spring to give some tension. Evidently when the cable was disconnected this allowed the spring to rotate the valve 360 degrees as spring tension released. I rotated it back 360 and got tension on the lever but the cable still does not retact completely when throttle is opened and closed. There seems to be a catch or binding of the cable somewhere that will not allow the lever to return to the idle position.
Any thoughts?
I've sent a PM to Nate as he has the same model but he must be out enjoying his craft.
Any thoughts?
