First I want to say any ideas on this subject will be helpful and appreciated. First I have a 1997 seadoo speedster. Twin 720 engines. I got the boat last summer from Florida (not takes care of and eat up with salt water.) last summer I replaced all the cables, had both carbs rebuilt, flushed everything, and hit the water for a short period of time. My port engine quit running and after alot of testing and swapping from the running engine I found the stator went out. After replacing the boat ran great. At this time I also changed the carbon seal. This summer I ran the boat one time and due to salt water destroying orings water got on the piston and put a hole in it on the port engine. I took the engine to a local dealer and the told me just do a top end rebuild. While they were rebuilding I trimmed the plug wires. When I got the engine back and installed it, it wouldn't crank. I have 135 pounds of compression, strong fire, the plugs are getting fuel because I can pull them back out and smell it, but I am not getting the engine to crank. The battery is good, fuel is good because I can fire the starboard engine right up. I checked the mpem and had little corrosion on the grounds, cleaned it up, and still the boat won't run. Also the boat had the oil injection bypassed before I got it so I am pre mixing 40 to 1. If anyone knows where a complete oil injection system is I am interested in it also. Please help me get my boat running. I know basics as i am an auto mechanic and there are no seadoo dealers in my area. Thanks again for any advice you provide.
