SeaDooGood
Make sure the air box cover is on correctly also. It may be pulling air from the sides giving you the whistling noise.
Still new to all of this, but the way it works is air is pulled through each air intake opening on the sides and run through to the engine to cool it correct? Once the air gets into the engine does it also go through the air intake silencer? I've only had it a week, so I haven't lubed inside the air intake silencer like it states to do after flushing for 3 minutes.
