SeaDooGood
HELP! 97 Seadoo XP cavitation issue and whistling noise question...
I just bought a used 97 Seadoo XP in overall really good shape. Tested it and ran good. Then brought it out to the lake this weekend and rode it and during the second day of riding it I noticed it started making this weird distinct whistling noise only when pressing the throttle down and accelerating. It would do it almost all the time. Then I started to notice that it seemed as though the impeller was spinning but taking a while to "catch" for the jet ski to get out of the water and on step. Once it got on step it would run fine and top out around 55mph, but it would still be making that whistling noise. This is the first jet ski I've ever owned so I'm a novice at this. I've did a lot of researching and wanted to get some more professional opinions on here. My first thought is to take the jet pump out and check the oil in the cone and check the bearings. Would bad/worn out bearings cause this problem? Do I need to take the driveshaft out to? What color should the oil be in the cone? Just trying to figure out what I need to mainly be looking for. My second thought is that the splines on the drive shaft might be worn out and that is why it isn't "catching." Any thoughts on what's y'all think is the problem and what I should do or check first? Thanks!
