I just picked up a 2005 sporster Le Di that ran fine last year but it broke down this year the first time out. Not knowing anything about these machines I have been stumbling over my own feet. I charged up the battery, hooked up the garden hose and went to start it a couple days ago. I did not know that you must have the engine running before turning the water on so I filled the engine with water like an idiot. After pulling the plugs and turning it over I got all the water out of the cylinders, but I don't know how to check to see if water got in the crank case.
I then started inspecting everything and discovered a couple blown fuses and I think I found what caused it to break down in the first place. The plastic box the coils and starter solenoid sit in did not have the cover on it and it had water in it. After cleaning connections on everything I got everything on the boat to work except for the starter solenoid. When I push the red button the fan comes on and the fuel pump. While someone holds he red bottom down I can jump across the starter solenoid and the boat will spin over and try to fire up every once in a while but it has not started yet. I am thinking about buying a can of starter fluid spray and trying that.
I do not know the first thing about Seadoo's or rotax engines but I do know engines and I know how to work on them. I just finished building a new LS3 427 stroker not a month ago. Can you guys please give me some advise as to what I should be doing to trouble shoot this thing. The last owner had it at the dealership and the tech said it needed a $1000.00 epmd, but from what I am seeing the computer is working fine because I have fire and fuel. The black safety cap is wore out and I have to jiggle it around from time to time because it loses connection. I also checked the switch on the shifter and it seems to be working fine.
Other than not running the only thing that is not working correct is the starter does not turn over when I push the red button, I have to jump the solenoid. It has fuel and it has Seadoo synthetic oil.
