As everyone has stated here having the same issues with my 2000 787 RFI ,, hard starts in water ,, perfect starts on trailer, compression good, rotary clearance good, etc etc,,,,, I DID get new injectors put in a few days ago as I read this may be the cause,,,,,, result,, it is better but not perfect,, it well start 8 times outta ten now in the water if you open the throttle a little bit, ski runs perfect in water after getting it started 6800 rpms etc etc,,, its just so the frustrating the two times outta ten that it wont start grrrr,,, I hope we can get this resolved if we all work together as i have read online about many of us having this issue, have also checked the rave valves and all these are in spec and a new starter solinoid was installed also with a 300 cranking amp battery, so so far we can rule out injectors battery and starter dragging and compression as mine is 150 150and rotary valve clearance , am thinking coil buyt that just doesnt make any sense to me since it runs fine when started.... keeep posting please we will get this resolved
