Have you checked that is charging?,,,my intent on the battery story was assuming that you had load tested it,,,at fully charged...you cannot load test a below spec battery,,
,so next,,have you tested for charging?,,to rule out the rectifier or stator,,,it could be one if them,,,if you are not getting 13 plus at the battery,,,then disconnect the rectifier, and test that the stator is okay,,its in the manual,,but my progression in order of ease, it see if a winding is shorted to ground,,,then do an ohms test,,,around .1 to 1.0 i think,,,its on line,,,if these tests pass,, set your meter for AC volts,,,number the 3 yellow wires 1, 2,3,,,,i usually put 1, 2,3, small zip ties on each wire,,,then start it,,,and check for the voltage between the 3 pairs,,,1/2,1/3,2/3,,,they should be equal and 25 plus volts and up when you rev the motor,,,the short to ground test is not perfect,,,i have had stators that only short when they run and get hot,,,if these tests pass,,its the rectifier.
