gsx cutting out
JUSTASTANG
i have a 98 gsx ltd that i just took out for the first time. ran pretty good at first then it started cutting out and die once in awile. i have to wiggle my key to get it to crank over and start. the key is new. the cutting out doesnt matter if its at low or high rpms. does not do it at idle or just off idle.any ideas thanks.
Post....
Sounds like your post is bad. The same was happening to me on my 1997. So, I think with age, the magnet of the post gets weak and is not able to transmit the information from the ROM (read only memory) chip inside the lanyard to the mpem.
At the top of the page is a search engine. I know there have been test for the post already discussed in earlier threads. See if you can pull it up.:cheers:
