98 gsx limited 951 carb adjustment
mikispike
so i got 1998 seadoo gsx limited 951 carb oil pump deleted its a premix
i got the air silencer from ebay assemble it adjusted everything to manual setting on carb, carb was rebuild base on previous owner.
the issue i got is the ski dies on acceleration but if i rev it few pumps it goes fine if i let throttle go and ski still move but not idle speed it will accelerate on spot no engine die or anything.
so i set the carb to factory setting high it close the low is 2 turns out, my question is if i wanna do it right what i do first do i set the throttle cable first or do i set the idle rpm first?
i know it nob question but no where it mention what to set first rpm or throttle cable.?
manual said 2 turns out for low speed but the website for sea doo setting said is 1-1 1/4 which one is right?
thanks for all the help im on my way to the lake as i write it hope will get some input by the time i get there
Step 1 is to verify the PO actually used genuine mikuni parts including new needles and seats and follow the Carb Rebuild Sticky.
Make sure the accelerator pump is squirting.
Make sure you have slack in the throttle cable before messing with the idle.
He claimed to use all oem mikuni parts.
Accelerator pumps does squirt.
I have slack on the throttle thumb.
My gauge isn’t working to I replaced it with marine gauge from Amazon and it’s reading the rpm when I went to try to adjust the idle I notice the rpm won’t raise up sound like it when up a bit but rpm read same and ski on trailer in water don’t push stronger.
That’s why I wanted to readjust idle and throttle but don’t know which I need to set first.
And thanks for your input!
Some of the cheap rpm gauges don't sample fast enough to do much good. I only use TinyTach brand ones.
Accelerator pump system. You can delete that by installing larger jets. I have never deleted it but sometimes it is difficult process to clear the problems and get good flow and pressure retention. There are good thread on the forum concerning this. For instance there is a small orifice in the feed line to the accelerator pump what some people might miss when replacing the hoses. The check valves going into the carb nozzles can become plugged. They need to be cleared and cleaned so they hold a little back pressure which will keep the lines filled.
If you give a 951 throttle and it falls on its face generally it is the accelerator pump. Mostly prevalent at low RPM and sometimes the engine will bog so bad it quits. Good Luck !
