Well I got everything back together on the 1998 XP last night got the hose on it cranked it over a couple times to get the gas back through the lines and she fired right up! Put the timing light on it and got the idle to 3000. Purred very nice. I replaced all lines and rebuilt the carbs. I noticed that the low speed screws were not the 1 1/2 turns out like they should have been so I did change that.
What next? I would like to do a tune up maintenance wise. I put new plugs in it and it has fresh gas. I greased the bearings near the pump. Anything else I can do?
I believe this ski has less than 60 hours on it. The GTX that I got from the same guy says it only has 67 hours on it, and it looks a little rougher around the edges...
Thanks for all the help!
Couldn’t have done it with out you guys!!! :cheers:
