Gainsville Area Auto Mechanic ?
Spimothy Leary
anybody live in this area and can recommend a decent domestic auto mechanic ?
94 stang... daughter is up there in school, her car will crank but won't turn over,
need to have it towed somewhere, and prefer just to not google random shops.
Thanks in advance
Thanks in advance
Have you tried calling Luis from stangsofflorida?
Fords are known for fuel pump issues so have some one smack the gas tank a few times rather hard and see if it starts. Also when you turn the key on you should hear the pump run for a few seconds. You may need to have someone listen at the fuel filler neck while the key is turned on to hear it. I owned a repair shop for 40 years and when ever a car would not start fuel pressure was the first test to run (on fuel injected engines) and then a rubber mallet was used to hit the tank a few times and most of the time we drove the car in rather than pushing it in. Rick
