Will a bolt type wheel puller work? or the ones you borrow from autozone work? I would like to remove the stator cup to wire brush that as well and get all the rust that had built up in between the crevice of the stator cup and flywheel off.Either mark the stator cup or better yet put the bolts back in as they don't need to come out to remove the flywheel. If you get the timing wrong you will have lots of issues.
Buy the correct flywheel puller.
I did pull the oil from the crankcase "hole" suggested from another thread, didn't look fouled from water or rust.... just old and black. Want to avoid opening any more "chambers" as all these gaskets are really pricey. I figured once I get to opening the crankcase its pretty much a full engine rebuild.....absolutely necessary?Lots of salt deposits in the water jacket
Alright. You convinced me. Lol thanksNo gasket on bottom half just sealant. If any of the bearing are bad on bottom it won't last long and the result will be catastrophic. Meaning new cases crank counterbalance ect. 951 rods have been known to even destroy the carbs if they grenade
So I haven't gotten the flywheel puller in yet to take that off and split the cases yet, but on a side question, what would be the best way to clean that besides a tube cleaner? I saw some guy boiling theirs in water with salt off in a big pot Its mostly fresh water lakes here, but I do intend to go to San Diego and take these to the ocean. I've had experience flushing the engine with the hose hookup with salt off, but that's it.Lots of salt deposits in the water jacket
I hope you were kidding, that piston and cylinder are trashed.
Something let go and that is why the head is damaged. The exhaust side of the piston is missing from detonation from running lean probably dirty carbs/fuel system.
That engine needs a full rebuild with cylinder boring and new oversized pistons, a new crankshaft and rebuilt balancer, new reeds and complete fuel system overhaul.
You should be prepared to spend around $1,200 to get it back on
I don't normally recommend sbt but I would send them this as a core for a rebuild.
If the crankshaft is ok, then would it be possible to resleeve the damaged PTO on the upper engine and just replace the piston and rings with the standard size and just hone the cylinder? Again, doesn't look like there was damage in the crankcase, reeds look almost new with nothing missing or worn and I've already replaced the grey fuel lines and will be rebuilding the carbs.....I hope you were kidding, that piston and cylinder are trashed.
You should be prepared to spend around $1,200 to get it back on the water.
Lol alright, it's a B@#%$ to crack apart....sealed pretty well together. I tried putting a washer in that crevice and twisting a 1/2 breaker bar to try and split it, but it's gonna take major muscle to do.... but after I take it apart and can take a better look and hopefully the bearings are ok I'll report back.I just can't see enough of the crank to make me feel 100% comfortable to call it good. You can do a visual on the outbard bearings but you can only feel the inboards and the rod bearings. I'll have to talk to my race bike building buddy about that. He'll probably say just rebuild the crank and you know what you got.![]()
Yup they are sneaky, looked again and forgot one in. Opened easily after that! ThanksBe gentle and make sure you have all the bolts out. They are sneaky.I find the slots between the casing and insert a strong screwdriver and I twist it gently but firmly a little at a time on each side. The cases will open up.
