I was changing out all of my gray fuel lines because I've been having a problem with my 00 GTI bogging down when I give it gas, and I have already rebuilt the carbs. During the process of changing the lines one for one, I decided to blow threw the Reserve line to see if it was free and clear and to my surprise I felt pressure build in the line. Sure enough when I took my mouth off fuel started gushing out. I then plugged the line and opened up the gas cap and sure enough I could hear air pushing out once the seal was broken. When I was changing out the lines on the vent side of the system I noticed that the little "check valve" that is located just under the rubber bumper in the hull isn't letting air in or out which seems kind of funny. The other check valve which is located behind the fairing just underneath the oil filler neck only lets air come in. I was just wondering if this is normal because it seems like the tank should be able to vent out and in depending on the situation.
