ldclarkejr
I had a problem with my 1996 xp (787). It hesitated when I accelerated, and would cut off if I didn't let off the throttle. Looking back, I think this original problem was the fuel filter in the carb. But, I rebuilt the fuel pump (including the carb filter), replaced the gray fuel lines, put in an in-line fuel filter, cleaned the fuel selector switch. Now it's not pumping gas. I've taken the fuel pump apart several times, but I can't find anything wrong. I put a pump bulb in the fuel line, and it will run if I pump the bulb. I can't thing of anything else to try. Help!! Thanks. Oh, and also, I am getting the engine pulse going into the fuel pump.
