Well Hello Again,
I just took my newly rebuilt challenger out for its 1st run
since its rebuild. I didn't even make it passed the no
wake zone when the motor stopped and smoke billowed
out from its compartment. When the smoke cleared I
could see two things wrong. One of the carb fuel lines
had melted against the exhaust header and was leaking
gas into the bilge, also the 1/4in. line from the exhaust
tube to the bleed outlet had melted off its connection. I had a purple fuel line on the carbs. I am lucky there was no fire or explosion. My question is, can I replace all of
the gas tubes with a heater hose for safety, or what do
you recommend? Do you have any idea why the water stream tube melted? The cooling lines are routed like the
manual with one exception, the pressure zone thru hull into the pump is not connected and is filled with silicone.
Sorry for the lengthy description.
Please help, I am very leary now after this scare.
Thanks, LindaP
Thanks, LindaP
