Fuel Light 96 Gsx
alexb
The Fuel Light Stays On All The Time And Dont Really Want To Pull The Baffle Just Want The Light To Be Out, Can I Jump It Out, I Tried The Unplug Thing And It Showed 12v Low So That Want Work But Think If I Jump It Out It Will Just Show Full All The Time But Not Sure It This Will Hurt Anything, Anybody Know?? Thank Alex
Alex you can unplug it and jump it but I would recommend you repair it. It is simple to check. Here is some info on the sender;
You need to check the Pink and Pink/Black wire coming out of the baffle tube in the gas tank. The sending unit works off resistance. Pull the plug apart at the tank, and use an ohm meter to check for resistance between the two pink wires. The resistance will be different depending on how much fuel is in the fuel tank. If you get no resistance, remove the clamps off the sender, and pull the sending unit out of the fuel tank. Check the magnets on the float in the sending unit. To get to the float out, pop the bottom off and look for the 4 magnets on the float. If they are missing use a strong magnet to get them out of the tank bottom. If they are dirty clean them and re-insert it back in the baffle tube and check the wires again to check for readings of resistance depending on where the float is in the baffle tube. Check the float to see if it “floats” in a cup of gas. Sometimes the float becomes saturated and won’t float in gas…but it will in water, so use gas to check it. If still no reading of resistance replace the sender. If you get readings, check continuity of wiring to gauge. At the baffle you could un plug the guage and using a jumper wire between the 2 wires in the plug on the guage side. Attach the lanyard to power up the gauges. If the guage goes to full the guage is good. If it still doesn’t respond, do a continuity test of the wires to the guage. If all wiring checks out ok, and the guage still doesn’t respond, the gauge is bad. Keep me posted on your progress.
Karl
I Was Thinking I Had To Take The Baffle Out To Get To It, Its Very Tight Under The Steering Section , But Will Give It A Shot, Will Be On Vac Next Week So Will Be The Following Week Before I Can Get Into It, Thanks For Your Info. Alex
GSX is a nice boat. Treat it like the nice boat it is and fix the fuel baffle properly....it will make the light go out, make fuel reading correct and will last a long time.
