lilskipp84
I just replaced all fuels lines on two 1996 seadoo xps. One i had to remove carbs to replace the connecting lines. Afterward, i notcied that ski is now idling unusally high. Compared to the other, it sounds like this one is at half throttel. Im wondering is I messed up reinstallin the carbs, esp the gasket between the carbs and motor. Would that cause this to rev at idle? And what is the right way to reinstall the gasket between carbs and motor. Was a challenge lining up the carbs, screws and gaskets all at once. Thank you
