Sorry for the delay, I couldn't post from my phone. I have another issue now. The temp sensor readings were within range on both the old and new sensors. HOWEVER, the blue/brown wire has been unplugged by the P.O., so no voltage to be read there. I belive (no schematic) that I can see where it should plug in, but there is a wire going to a ground terminal in it's place. This wire does not appear to be OEM. If I understand all this corectly, the P.O. basically bi-passed the Temp sensor and lied to the TPS. If I run my meter between brown/black and the wire I believe brown/blue should hook up to I get 7.46v no matter what position the throttle is in.
