Dr Honda
no matter how much throttle i give it the most i can get from the tps sensor from any wire combo is .098 vdc...
Hummmmmmmmmmmmmmmmmmmmmmmmm............................
OK... I'll get back to you shortly.
ok thanks tony, im about to head to work now so ill check up on this later... I have all day tmrw to tinker with itHummmmmmmmmmmmmmmmmmmmmmmmm............................
Did you follow the book?
Did you disconnect the tan/black wires at the port temp sender?
This issue forced me to look over the wiring... and it's interesting. The port temp sender is directly connected to the the TPS. That's how it adjusts the fuel. It basically moves the TPS value, to "lie" about where it's at.
yes but since i dont have the test lead assembly i guess i cant do the test unless i make my own? thats probably whats screwing it up i was reading tight off the tps connector
Then how did you do it? The TPS has to be hooked up, and the system turned on.
Yes... you should be able to make your own leads... but in a situation like this... I push pins though the wire jacket to read the voltage. (basically, it a wire tap)
Ok so as it sat the meter was reading 3.4v at idle.. I adjusted it as far down as I could 1.6ish vdc at idle and 3.8ish vdc at wot
It could be.
yea ill pull it off in the morning and grab some shotsIf you pull your TPS to get a better look at it... post up some pics.
Thanks. That would be good.
The wife had a dumb movie on last night... so I dig around, and found some interesting TPS unit's to look at.
1) 90's Jeep. It has the wires hanging off, and is close to the same housing. (about $40)
2) Late 90's honda. Has the nice mounting tabs that allow it to be adjustable. (about $30)
3) The Merc DFI TPS. It crosses to the newer outboards also. AND... there is a possibility that it has the same internal value since it's from a Merc engine. The problem with that one is that it's a TOTALLY different housing. BUT... it's $80 or less, and if it's "Electrically" correct... I'm sure I could machine an adapter that would be $30 or less. (that would turn it into a $100 option)
Regardless... with the TPS being around $500... that leaves us a lot of room for experimentation. (I can't imagine why it's so expensive when automotive units are in the $50 range)
One last thought........
I'm not sure that the engine would run if the TPS was bad. So, just for giggles try 2 tests when you take it off.
1) Try to throttle up the engine, with the TPS off the throttle body, but still hooked up to the wires. (I want to see if the engine will rev if there is no change in the TPS)
2) Try to start the engine with the TPS disconnected.
