Is there any problem with using the oil injection system and premixing a little oil with the gas?
Previous owner(s) installed a SBT engine in the boat and went with premix, however they never disconnected any of the lines and just empty out the oil tank. SBT didn't inform them that they need to keep oil in the lower case for the rotary gear and bearings.
I rebuilt the engine when I was having problem with the engine (was a broken woodruff key on the flywheel) that was messing up the timing. I checked the oil pump when I had the engine apart and replace the oil lines. I ran premix 40:1 with the first 5 gal. of gas but have been running straight gas with no premix once I saw that the oil lines were filled with oil.
I might go with a 60:1 premix mixture just to be safe.
In the case of a carbed motor such as this one, the fuel can be pre-mixed in addition to using the oil injection system but to go off injection completely the carb really should be rejetted richer by the percentage of the oil ratio. Does anyone ever do that? Well, not many do, they just mix and go.
The rotary valve motors need to have and oil bath maintained in the RV drive gear box, so at least make sure if your motor uses an rotary valve industion that gear box always has oil in it while the engine is running or else the gears that drive the valve will be damaged.
Adding some amount of oil to the fuel in addition to using the oil injection system adds expense to operating costs and is unnecessary if the oil injection system is properly maintained, such as adjusting the control cable properly and checking it, also the oil lines tend to rot and crack over a decade of use along with the oil can congeal inside the nozzles, the oil strainer should be replaced probably every few seasons as well.
So my feeling is, the variable ratio oil injection system is quite robust and it's worth the trouble of keeping it maintained b/c it will save you money over pre-mixing due to lower operating costs.
It's quite common to dump some oil mixed with fuel into the fuel tank if there's a reason to believe the oil injection system might be malfunctioning, such as for instance it was just serviced and may not have been purged of all air bubbles or the control cable was accidentally broken somehow, or for whatever other reasons it's okay to add some oil to the fuel temporarily until the oil injection system is repaired and proven functional.
If for instance I had just replaced my motor and of course this means the oil injection system was also just reassembled thus might not function properly, then I wouldn't hesitate to add oil to my fuel until I had the opportunity to test the oil injection system for proper function and make sure all of the air bubbles had been completely purged from the system.
One way to test the system is by with engine running on pre-mix pulling the cable to open the injection pump valve about 60% of normal travel while fast-idling and watch to confirm the system delivers a ton of oil (smoke in the exhaust).
