Waterluvr
All you need to do is place a channel lock on the opposing fuel supply hose to the other carb in order to eliminate that being part of the issue (I don't think it can be but why not seal it anyway just because) and place vacuum to the supply line you want to test for fuel flow. You should be able to draw fuel to it right away, if not your issue has nothing to do with the carbs themselves and you need to find out where the issue is or the boat won't run.
I use a brake bleeder with a hand pump and a recovery cannister to check for these type of issues, a few pumps to introduce vacuum on the fuel line and there should be gas drawn to the recovery cannister pretty quickly once it primes. I would suggest checking it with the fuel selector valve in all three positions to make sure the primary, shut off and reserve functions all work.
If you're not getting fuel that way, stop and remove the selector valve you'll find the problem there unless you have taken the fuel baffle out to service it or the float and the lines weren't put back in the proper location.
I'll be on the lake tomorrow and wanted to leave you some more info to work with if you needed it during the day, hope you get her running let us know how it works out for you.
