delta_shop
One day my 2004 Seadoo GTI LE randomly died while going full throttle. After trying to turn the engine for a while it started and worked again. and it died about 5 times. After letting it idle for about half of an hour without any fast driving the jetski started working nicely again without problems ever. Next time on the lake a rope got sucked into the intake grate and I had to flip the jetski to unscrew the grate and cut the rope out. A pretty bit of water got into the engine. Third time on the lake, the Jetski started, worked for a bit then started getting the same problems but even worse than the first time, it wouldn't want to idle and kept dying over and over until the battery died. what do you guys suspect the problem might be?
