Electrical Issue
FLSeadoo1
I went to check on the boat today and start it up and make sure everything is good. I start the boat up and it runs fine with no issues... The gauges work and the electronic information display is working as well..(Menu/Settings/RPMs/Etc).. However none of the accessories are working... No lights, no horn, no blower, no radio.. It is like everything that has to do with the boat running works fine but nothing else... any ideas what this may be? 2010 Challenger 210 SE.
Thanks
It sounds like it has lost the "accessory" feed from the ignition switch. I don't know if there is in fact a separate line for your accessories, just saying that is what it sounds like.
If you can get to the ignition switch, test for voltage/continuity from each terminal. If there is, then follow the wire to where it is likely fused and gets distributed to the various components.
I don't know if there are fusable-links such as there are in the automotive world or not, but if so and it is blown, this would cause the same effect you are having.
Coastie, thanks for your response.. Turns out the main breaker coming off the battery switch was partially tripped and I just overlooked it... Kind of embarrassing to say but I got it fixed..
