My son was riding our 1996 GTi Sea Doo and it was running great for the first time out for the year. Then suddenly something was grinding and he lost all forward momentum. Engine would run but a lot of grinding and you could hear something was broke.
After a bit of investigation i found that something broke between the front end of the drive shaft where it enters the engine (PTO??) After removing everything so that i can remove the drive shaft, i found that i can push and pull the drive shaft fore and aft about three quarter of an inch and rotate it almost 360 degrees, but i'm totally unable to pull the drive shaft out of the engine.
in the driveway i can run the engine and you can see that the drive shaft where it exits the engine it's grinding and the drive shaft barely spins at all...
Help!!... i need to get this thing back on the water this year..
Scott
Scott
