Di pistons
No and nobody can tell you that, all depends on use and maintenance.
General rule is 200 hours but then again the can go longer or shorter depending on fogging, water ingestion and oil used.
I took a Di apart that had over 200 hours, many were at full throttle. The pistons were in very good condition. It the engine is maintained; they will go a long way. Try removing the RAVE valves and looking at the piston skirts. That should tell you a lot.
They all work really good if you feed them right and treat them right. Problem is you never know what the previous owners did to them.
I use WSM and not even the coated ones. :) I can't comment on price. I'd suggest shopping around. Good Luck !
I have one good piston that says Elko on the inside. anyone know where I can get new piston rings and also can I run that with a different piston brand?
As in your other thread, ELKO is the OEM supplier, new OEM rings can be bought from Seadoo.
Any seadoo dealer or online site selling OEM parts.
I would suggest seadoowarehouse as they are a site sponsor.
