eddie708
Before putting anymore money into it get a updated compression test. if u get 150 and 125 again its time for a motor. if u didn't already replace fuel lines and clean the carb filters start with that. also if you do a search u will find that the only recommended starter is oem anything besides oem is considered junk and will most likely stop working within the first few months. u can rebuild ur oem starter for under $40. if you rebuild your carbs only use mikini carb kits. i would also recommend sending them to dr.honda, jetski carbs are more involved then most carbs used on dirtbikes and atvs and most new guys will not get it right there first time. i know i didnt. As far as only reving to 3500 start at the regulator. it the box with 3 yellow wires and 1 red comming out of it. unplug the red wire and then start the boat and try it.
