anthonymsaad
anthonymsaad just schooled anyone that thinks this will work! Should be permanently posted to this section.
Last night, I took my 08 Speedster 200 430hp out for it’s maiden voyage (my first boat). Made the mistake of warming up the engines at the dock on the dirty Delaware River here in Philly. They weren’t running for no more than 3 minutes before sucking up a big thick chunk of plastic (almost the top to a 5 gallon bucket) I tried the conventional OUTBOARD engine “trick” and it didn’t come close to working. If anything I just made it worse. Had to pull the boat out of the water, get it on the trailer and ultimately disassemble the rear drive. That process was relatively easy but a simple inspection of the water intake and the mechanics of it all clearly shows that the “tricks” mentioned above are only going to make the matter worse.
After clearing the drives this morning, I put it all back together and tried for round two of its maiden voyage. Very impressed with the power, the boat really hauls ass! Went about 1 mile downriver at 3/4 throttle, did some tight maneuvering before promptly sucking some twigs and a plastic bottle cap into the intake again!!! It’s always something!
So now I find myself joining this community because an amateur like me really needs a quick education. I haven’t ran this boat for more that 5 minutes at it’s full capabilities before getting myself jammed up again. Had to idle back a mile upriver and trailer it again.
I’ve purchased an “unclog kit” from Harbor Freight (pic attached) and hopefully I can fish this material out without disassembling again. This seems to be the legitimate “trick” for these boats. View attachment 35855
A few questions I have:
Are there intake grates that offer more protection? Basically, I don’t think I can run this boat in the Delaware River unless I can replace the grates with something that has tighter gaps.
Was I operating it wrong? I only did, 3-4 tight turns (not crazy turns).
I’ve attached another picture of my grate, does this grate appear to be stock or after performance type for max intake?
I called a few dealerships and nobody seems to service these boats or offer much advice. Can you all recommend an aftermarket grate that will offer better protection? I see PWC’s running this river in packs of 20 all the time. Are their intakes much smaller and have tighter grates with the ability to sift through foreign material better?
Sincerely,
Skipper Tom - Amateur Hour on the Delaware
Hey! Thanks for the appreciation! Im not too familiar in the factory intake grates, but I would say yours is more on the factory side, as it looks like mine. Moreover, performance grates generally have a bar that rungs perpendicular to those grates that helps redirect additional water up into your jet pump. With more water being forced in, more water can be forced out, along with a reduced load from pulling in water, which results in better performance.
Regarding getting an intake grate that is narrower and protect you against sucking in foreign objects, that would be tough. If you go too narrow, add more bars, you can restrict the flow of water into your jet pump, which will lower your performance. For me, I have similar concerns as you and trying to find an aftermarket performance intake grate, one that has a bar midway. It will help reduce the physical opening of objects that can pull through, but also improve performance.
If you can tell me more about your river, can try to offer some additional insight. I find it odd that you sucked something in twice so soon after leaving the dock. Do you know how deep the water is and, do you have a depth gauge on your boat?
