Well, it was uglier than expected. There was no where near enough shaft sticking out to grab. Option 2, left handed drill bits and screw extractors. After two broken drill bits, and trying to drill out high carbon steel, we were left with a nice hole in the cast aluminum much larger than the screw.It's been in storage all winter, so I have not dealt with it yet. It's snowing again today, but at least the ice is coming off the lakes. I HATE TWEENER SEASON!!
I'm guessing, I will pull the plate and hopefully be able to get that broken screw out with a vice grip. I will replace and see how it goes. I may order the screws listed above, but I am unsure if they are any different than the ones I already have.
Good luck!
JB weld aluminum filler, drill to size and tapped for threads. Then we let it cure. I now have a new screw in there and it's holding. For how long, I have no idea. It really needed a welder to go in there and weld in fresh metal, drill and tap, but that will be the long term fix next winter. What a pain.
How did you get your sheered ones out? Easy outs? I just hope this is not an issue for anyone else. I still think it was my dealer being careless. Who knows.
Good luck all, don't let this scare you from the plate as it should not.
Well finally got the boat yesterday. The winds were light and the sea's were calm. This ride plate worked better than I could have dreamed of. The boat got up on plane quicker. I ran the boat at varying speeds with absolute no Porpoising. I could not believe it. The speed range where porpoising was the worse around 4000 rpm's there was none. We cruised slow 20 mph to wide open 52 mph ( I estimate I lost about 2 mph with the longer plate) with no bounce. We were able to pull a wakeboarder at 18 to 20 mph with no difficulties. It was great!!
The tracking of the boat also improved. Before the boat would pull to the right. I would have to counter steer to the left quite a bit. Now with the new plate the steering wheel is straight with very little counter steer to the left. I think by lowering the right side of the plate, will get rid of all the pull to the right. This ride plate is the solution to the porpoising problem this boat had.
hi guys- I'm gonna break in here and ask a few questions- my 2000 challenger 1800 is porpoising badly at 30 mph. the guy I bought the boat from appears to have installed this extended stainless ride-plate. I'm assuming this is my problem. I had a 2000 20' challenger and an 18' sugarsand mirage with the same merc 240 M2 and never had this issue, now this 1800 is all over the place. would removing the plate or cutting it shorter reduce the porpoising? would raising the plate up closer to the jet or lowering the plate so it's pressing more in the water resolve the issue? I'm ready to take my .308 and sink it! :facepalm:
Those pictures are the extended ride plate. But it looks like it is flat to the bottom of the boat. The rear screws towards the jet nozzle should be adjustable. The more you lower that plate, the less bouncing. Give it a shot, as without any plate, or going back to stock is worse.
If those are your pictures above, you will note that there is no gap between the black cast piece of the pump, and the nut on the bolt through the ride plate. I have to look at mine, but I think I have nearly a half inch of exposed bolt! Adjust that sucker out and enjoy!
Good luck
