Hi folks, newbie from New Zealand.
I purchased boat and completely rebuilt the motor including carbs.
After run in and about 10 Hrs, I had a PTO piston seizure.
PTO piston is toast, with a hole in the side of it.
When it seized, I was pulling a tube and had 3 adults in the boat, so was loading the motor. Found out that the pto rave valve piston cap was broken, so it wasn't opening.
Do you think this would cause the seizure?
Pulled motor, did leak down, all good.
Rebuilt carb specs - does this look ok- should I run richer on anything?
Pop off 36 psi
Mag main 142.5
PTO main 145
Pilots 65
HSA 0
LSA 1 1/8
Pop off 36 psi
Mag main 142.5
PTO main 145
Pilots 65
HSA 0
LSA 1 1/8
![IMG_5885[1].JPG IMG_5885[1].JPG](https://www.seadooforum.com/data/attachments/26/26509-9b3cc6d1a20886b9e3d5ae0fadfe2a3c.jpg?hash=mzzG0aIIhr)
